60 degree profile
chuggy
5 Mar 2008
I am looking for a couple of metres of 25mm x 25mm 60 degree aluminium or mild steel 'v' profile or even a hollow triangular section.
Any ideas ??
Thanks for the reply, John. Great source of profiles but, unfortunatel, not the one I need...
The hunt goes on.
I reckon that is going to be tough to source. Any way of modifying what you are doing to take 90 degree angle?.
Also bear in mind that the angles on profiles are not that accurate.
Bob
Have you got a local metal fabricator near you with a press break, should be able to fold it up from some flat strip if you don't need it much more than 3mm thick. I've had bits of steel plate bent by my local fabricators, if you are lucky they wil do it for a drink.
Jason
