6 Head Moulder
Allylearm
4 Sep 2011
Stirlingshire
Now before you read anything I am a Weinig man and I used to be Wadkin, when its dealing with Moulders I cannot see past Weinig. So I am totally biased. I purchased this just before recession bit and other than our sister company new build we have not purchased since. It came in at under £80k I do not know what it now sits at.
Anyway I had a Unimat 23 purchased from new 1996 by a sister company that closed and it was moved with some other plant to existing position. My main issue was speed of setup, I saw the new tooling holder without shafts on a demonstration prior to us looking to replace. With the CNC setup you could auto move the heads and the machine could recognise the tool. So in theory you could speed between moulds to be run. I wanted to run smaller batches so eliminating shrinkage in assembly. If run what we needed my theory was that it would not shrink as much as it was causing us issues of running more end panels to finish certain tasks. So I looked at the Powermat all the above plus it was faster, this did work out and though not just in time production it was close as.
Prior to purchase I had been going through replacing cutters to tipped cutters due to cost and accuracy. Not that I am saying that you can get accuracy from serrated cutters/standrad tooling profiles but you best to profile on the head or you end up one doing the cutting and the others acting as balance. Plus labour cost of doing the profiling and sharpening was getting close to losing money and time I did not have so I needed to address sooner rather later. If you did not go for replacement tips route you would need Grinder/setting stands/Profile shaper which could add up to £50k to overall cost which is abit ouch (shown at end of vid).
So with the Powermat and it's switchable heads and no shafts, it is like tool changers on CNC Router they have a tool holder to hold the cutter block. So in this respect I was in front of this and did not have such a big outlay, only on holders though it did come with a good load to start with. It was faster in operation and was most importantly quieter as it came with sound proofing improvement option. A big thing in my workshop at the time as my Resaw and Moulders and sometimes the Beamsaw were my noise makers I had one long term goal to try and get well below 85db in full working conditions. Stil lnot there but that is another story.
Anyway this machine was fitted and even though staff were not convinced of the new fangles fitted in operation and use it won them over. It can be fitted with a web cam so you can take pictures of tools and store them in the memory or you can watch what they are doing on the machine from the office if you wanted. It is faster to tool change and with tersa and lighter blocks it is quieter than last model so was good in this respect. Finish is superb and I had the option of straightening table fitted.
This is not my machine we have only six head this has more but principle is same and setup mode and operation. The tool holder cart in vid is expensive and usefull, we made our own.
http://youtu.be/HQxRWDh_24M
Ally:
I'll be interested to watch the video when I get home from work tonight.
How long are your production runs? How many times per day or week do you have to change out heads to make other profiles?
I'm not quite sure I understand your sharpening paragraph. Are you saying you just leave the cutters in the head and sharpen in place, or that you have changed over to cutters that index in the head and just bolt on? If the latter, are these single use or do they get sharpened somehow?
Kirk
My production runs vary like everyone else depending on batch size or what is being made in assembly. At the time I was running Sheds/Garden Tables/Garden Benches that required square dressing or moulded. I have over the years got away from day runs on same componnets other than square dressing. I have been forutunate that my last shop had a 5 and 6 cutter. This shop has two 6 cutter, so in practice the new powermat runs moulds and I can leave the other square dressing varied sizes. In respect of setup the powermat can take 10/15 minutes setup time before was much longer and now we have the added advantage that each batch is exact same as last dimensions. Keeping the sizes or moulds in its memory prevent slip ups in setting.
Videos speak better than words, here is a auto grinder doing a straight profile on a head. When you send cutters like this away they just fit them on a holder, doing it on the head in position is far better and balances the cutters out as they are all true to each other.
http://youtu.be/vfnfq5845V8
Hope this clarifies what I was trying to write.
