pgrbff
I have two items I need printing, part of a featherboard, but have no idea if there are any small companies doing printing. Probably nylon type material.
Any suggestions?
Any suggestions?
Do you have a recommended link? I'd like to print one out. TaFeatherboards are fine in PLA. I have loads Ive made from thingiverse files. PLA is printable by many people / operations and is cheap.
Dont overspec on the material unless it is really needed.
I know less than nothing about 3D printing. I had a look through the types of material available and nylon seemed both durable and flexible. It was only a suggestion. Here is an image of the finished item. I have to admit I bought the kit because it was actualy cheaper than buying just the two magswitches, but the fence/featherboard might be useful too.Do you have a recommended link? I'd like to print one out. Ta
PETG looks OK but having never had anything printed before I simply don't know. I've posted an image of the fence, it is printed as 2 pieces.Does it have to be nylon? The strongest filament I could print them in would be PETG if that's any use
It isn't a standard featherboard, it's a combination rip fence featherboard for a bandsaw. Buying the entire kit was cheaper than buying just the mag switches.Do you have a recommended link? I'd like to print one out. Ta
That's very kind of you. I have been tempted to buy A printer but to be honest I haven't had a need until now. I'm sure going forward that is likely to change. If I send you the files would you be prepared to have a look?I second PETG as a cheaper and more accessible alternative. It will do the job fine.
I can supply the printed parts for you if you still need them or I'd be happy to recommend a few 3D printers to get you started![]()
Of course that's no problem! I'm new to this site so not sure how's best to send the files over... but I'd be happy to take a look for youThat's very kind of you. I have been tempted to buy A printer but to be honest I haven't had a need until now. I'm sure going forward that is likely to change. If I send you the files would you be prepared to have a look?
I was beginning to think I'd have to make them in timber.
