I think this is a home made bandsaw. I certainly couldn't do that cut with my bandsaw!
http://www.youtube.com/watch?v=YYbc7Q093g4
herdsman":eiwmb4u4 said:The trouble is, in my opinion, people carry out a dangerous technique without getting injured and this leads them to believe it is safe so they continue with the technique until the inevitable happens!
ByronBlack":18b311sg said:It does seem that americans have a very low regard for safety.
ByronBlack":8hqsvjyl said:It does seem that americans have a very low regard for safety.
MIGNAL":2xe1j4qf said:I think he's trying to show us all how good his home made bandsaw works, pretty irresponsible to be putting it on youtube.
MIGNAL":jis81lig said:
Any silly person who forgets the blade comes out the bottom deserves to have their fingres cut off! :tool:Mr_Grimsdale":v6rgec3p said:or you might forget that the blade is coming out under it and catch your fingers.
Really? So you've used a saw for 4 years, presumably without ever bothering to read anything useful about safety or have a training session - and survived. So what! There are many recorded instances of even experienced woodworkers who've used a rip saw sans riving knife, etc without incident all their working lives only to have a serious accident in their last few years of work. The riving knife/short rip fence are to protect you from the effects of reaction timber. They are nothing at all to do with being able to use a machine which is "wrongly set-up", because a machine which is correctly set-up has a correctly adjusted, properly sized riving knife, a crown guard, dust extraction, a short-position rip fence, a run off table and is supplied with at least two push sticks. Your table saw technique is both risky and unpredictable and most certainly not the "good technique" you would claim, and how would you fare if you were trying to centre rip a 12in wide piece of reaction elm and it parted both ways? Your technique of leaving a thin offcut to one side of the blade doesn't work in that situation..... Please go a read a book on wood machining and learn a bity more before youy do yourself a mischiefp111dom":1scgd190 said:I do find this safety thing amusing. While there's no doubt that riving knives and split fences do reduce injury’s that's only due to the fact that it allows an operator to use an incorrectly set up machine without knowing it.
Ninety years of woodwork machining practice says that safety is in the proper use of the safety equipment and in the adoption of the correct, i.e. the safe, technique by the operator. It is not a eye thing at all - it is a discipline, a mindset, in conjunction with training (book or class). It is probable that you've never worked in either manufacturing or construction where that sort of attitude could see you, and others, seriously injured.p111dom":1scgd190 said:IMHO The bottom line is that I think safety is in the eye or the user.
The piece being cut is very tall and has a very small footprint. The two dangers are of break-out of the blade from the edge caused by misfeeding (toppling) or of blade breakage as the hands are extremely close to the blade. Assuming that the blade is fully in the timber (and that you are therefore protrected by it) is probably the biggest mistake - on lighter bandsaws you really can't pull enough tension to guarantee that there won't be any bowing of the blade in the cut especially on deeper cuts. And in any case it is quicker and more accurate, not to mention a lot safer, to turn the piece on a lathe..... :roll:spadge":1scgd190 said:At the risk of getting shot down in flames what is so dangerous about this cut?
