Danny
Hi all been away from the forums for over a year due to lack of time and space for woodwork, and quite frankly visiting here can be depressing when I cant go out and build things
I'm currently looking into the possibility of building a rather large workshop and starting to look into some large machines for a change, naturally I have some questions!
First of all from a whole morning of searching I understand discussion of stacked dados still ends up in heated debate about safety / efficiency. Yes I understand the safety issues of stacked dados, and like most workshop machinery requires caution with use. And it's final, because I hate cutting a lot of rebates with a router. And if it takes 20 minutes to set up a dado cutter then I'm fine with it. So please please please keep it on topic.
I notice that the 10" Xcalibur 3HP Cabinet Saw is popular with a few people on the forums so would be interesting to hear some feedback from them. I'm looking at the 12" 5HP version due to the fact I work with chunky timber a lot and the 4" depth of cut is worth the extra cost for me.
So now for some questions:
1) The required arbor extension that Woodford list, is this something that has to be installed every time a stacked dado is installed, or can it be left on? I'm having a hard time trying to visualise what it will look like once installed so if anybody has any pictures I'd really appreciate that.
2) How good is the dust extraction on these machines? Do they require any modification or is it good enough off the pallet.
3) What dado sets are you using? I'm aware of the 8" freud set for around £80 from Machine Mart but is there anything better out there?
Also open to suggestions of other machines that are unbraked, can take a dado set, and has a 3/4" mitre slot, however I'm 90% sure the Xcalibur will be the one for me.
Thanks!
Danny
Thanks!
Danny
