8 inch 25mm bore stack dado
AdamMurphy
12 Dec 2020
Limerick ireland
Hi folks, looking for help in locating a 1 inch bore I inch stack dado to use on my table saw . Saw is a multico a3 so shaft is long enough . Any help would be great . Most I've seen are 5/8 arbor and would love to find one .thanks for your time
8 inch stack dado . Sorry
You have two choices.
Get a set from this side of the pond.
https://www.cabinetmakerwarehouse.com/catalog/prestige-dado-set-8-inch-dia-x-24t-h-atb-1-inch-bore/https://onlinesupply.ca/Drilling-Cu...ado/C-T-DADO-SET-8-x-24T-x-1-BORE-8-24-DADO-1
Buy a 5/8" set on your side and have a machine shop bore them out or good saw sharpening shop open the bores and retouch the teeth to ensure everything is round and true. The machine shop work will need to be sent to the saw sharpening shop too.
Buy the dado set to suit the material most used by you. There are sets for sheet goods and some for solid woods. Some will do both.
Be careful using them.
Thank you for ghe links . Appreciated
Thank you , that was the answer I was looking for in relation to the 30mm. . Any recommendation on the number of teeth . Mostly ply and teak will be used on . Thanks
The number of teeth is mostly irrelevant with dado blades as each side blade cuts the shoulders as cleanly as they can and the chippers chip out the material in between.
Plywood and Teak are possibly the worst choices of material for tooling longevity. If you plan on cutting a lot of it it may be worth investing in an adjustable groover from Whitehill instead, a lot more expensive and typically less capacity than a dado blade, but the carbide inserts are made from a much harder grade than tipped tools and are easier to replace than constantly having to have a dado set re-sharpened.
As a hobbyist it will be used occasionally so for that reason I'll go for the dado. Production worker would go the adjustable grover way. Thanks again for your reply
