JustBen
I've just moved into a new rented property and want to sort the garage(workshop) power out.
The workshop is attached to the house but on the opposite side of the house to the consumer unit.
I have investigated the power/lighting and the lights are connected to the downstairs lights.
The sockets are spurred from the upstairs sockets.
I would like to have the workshop sockets running off my rcbo in the spare slot but I'm not sure how to route it through the house as it's rented.
It appears that the socket that is in there is a spur from upstairs.
I want to add 5 double sockets and also keep the original socket too.
So, how would you recommend I do it?
Other than the chest freezer and occasional tumble dryer use, I would only have a max of 2 machines running at once.
The biggest combination would be 1350watt thicknesser and 750watt extractor so 2100watts + chest freezer + tumble dryer if on.
So other than running new cables somehow from the CU, what options would you suggest?
Fit a mini CU on the spur coming from the house?
Fit a fused box on the spur coming from the house?
I hope I've made it clear.
