I'm planning on a more permanent air set up in my workshop, my plan is to use copper pipe from the compressor to the outlets. I have load of 8mm copper pipe which it would be good to use, but I'm a bit worried that the ID will be too small - anyone got any idea if 8mm will be OK (the air system will mainly be used for spraying), or do I need to go for 10mm pipe?
