Wood identification
peterw3035
15 Dec 2017
Romsey, Hampshire
Could be ash, a lot of ash trees have been taken down due to ash die back. Does it have an open grain?
Adam W.
18 Apr 2021
London, Jutland.
That bone white colour reminds me of the Ashen tree.
And I like your turnings. Did you do them on a pole lathe ?
Penllysbach
12 Apr 2019
Llanfechain
Thanks all, I have some both holly and ash so can check against them. It was quite a small piece and I think part of a hedgerow .....
Re pole lathe, no but like to try working on one.
gregmcateer
16 Jun 2011
Stourbridge, W Midlands
I would have guessed holly as the grain is so pale.
But interestingly, I've just split some holly I was given, but it has the most amazing grain I've ever seen:
(NOT trying to hijack your thread, just coincidence I got this holly yesterday)
KimG
Little Woodworm
2 Jul 2012
Pembs
It's Ash, holly bark has small blister like bits on it a bit like Cherry and the grain doesn't have the open vessels the way Ash does, it's a much denser tighter grained wood that Ash.
Tris
What am I doing here?
28 Nov 2018
Moreton in marsh
Thanks, but doesn't ash turn link when cut?
Not always, I think it has something to do with the soil it is grown on, used to see it a lot on chalky soils but not on the cotswold brash.
The pinkness fades out fairly rapidly on most ash in my experience.
Regards
Tris
KimG
Little Woodworm
2 Jul 2012
Pembs
You mean Pink, yes it can do, but I think it may also depend on how wet the wood is as well as the the reason Tris gives, Holly to though goes through some very odd coloyur changes when wet, sort of a greyish blue green and quite pronounced. The bark though is the clearest indicator in these images, on a decent sized log like this the bark of the two species is noticibly different. Ill see if I can gig out a lump of holly and post it up for comparison.
KimG
Little Woodworm
2 Jul 2012
Pembs
Great pictures Linus, the tall log really shows clearly the small horizontal blister like marks characteristic of Holly, the slice through also shows the much closer grain structure too. Thanks! :D
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
It looks extremely holly-like - with the pale wood and the green cambium layer under the thin bark. If you scratch that bark/green bit you get a very distinctive "holly smell" (almost smells like a salad vegetable - holly leaves used to be used for animal fodder). Ash is different in several ways (it smells very different too!).
