I've just agreed with Jacob ............ I've come over all unnnecessary ...........
Don't worry about it Phil, everybody agrees with me in the end!I've just agreed with Jacob ............ I've come over all unnnecessary ...........
My Clearview worked out at £400 over every three years.I used to replace some/all firebricks on my picturesque Morso Squirrel every year, and the cast iron baffle quite often too. Probably added 25% on top of the fuel cost. Also it'd take much longer to heat up.
I worry more when they agree with you in the beginning.Don't worry about it Phil, everybody agrees with me in the end!
I piped in the cold air from outside for mine. There is a fitting on the bottom of the stove to attach it to.I have never felt the need for any additional air circulation with my multi-fuel stove, but it's not recessed. When I pre-installed it, I drilled a hole through the wall below and behind the stove for the air intake. The alternative was a vent above the door, but that would have caused a cold draft coming from behind the seats.
Over the past 20 years I've had three stovesWhy do you thing cast iron and firebricks is more efficient?
I've got sheet steel stoves and they produce heat cleanly and much quicker than the various firebrick/steel/cast iron versions I've had in the past. Also are maintenance free and cheaper to run.
I knew you'd say that Jacob, because you mentioned your preference a while back on another thread!Why do you thing cast iron and firebricks is more efficient?
I think you've been doing something wrong. All my (three) stoves are Morsos, but not Squirrels, and are used daily for several months a year. I've been through two sets of firebricks in twenty years!I used to replace some/all firebricks on my picturesque Morso Squirrel every year, and the cast iron baffle quite often too. Probably added 25% on top of the fuel cost. Also it'd take much longer to heat up.
I note from the sales description that the Ottawa 12 has both fire bricks and a cast iron backplate. I rest my case, m'lud...Over the past 20 years I've had three stoves
A dursley highlander 5 (steel)
2nd house
Nestor Martin 23 (cast iron)
The Nestor Martin was so bad we replaced it with a Ottowa 12 stove off eBay. (Steel)
Which is far quicker to heat up, burns better, stays clear, produces less ash and has a bigger ash pan.
No competition despite the nestor Martin being a "high end stove"
Cheers James
Followed directions fairly carefully as far as I recal.I think you've been doing something wrong. All my (three) stoves are Morsos, but not Squirrels, and are used daily for several months a year. I've been through two sets of firebricks in twenty years!
I sometimes burn anthracite, but I find it is more chemically agressive and it stains the glass - normally just dry hardwood (oak/ash/beech/hawthorn etc.). Anthracite normally reserved for the Rayburn, which is multifuel, but keeping that fed with wood instead would leave me with no time for much else!Followed directions fairly carefully as far as I recal.
Do you burn solid fuel? I did and don't think the stove was durable enough - bricks would crumble etc.
Probably a lot better (for the stove) to just burn wood, but then you need a much bigger stove to get enough heat out.
Could work - cheaper to run than to buy a collection of Eco fans......I have at various times thought about rigging up a small and quiet electric fan in the fireplace and seeing what effect that has, in fact thats the thing that might work best?
Steve.
I think you were benefiting from the "de-stratification" effect I first mentioned. Most of the heat from a convector goes upwards - and tends to stay there (there can be a 5C+ difference in our sitting room between floor height and ceiling height) - stirring it up a bit does help (probably disproportionately if you study the psycho/phsyiological benefits of warmer feet!).........
Adding a low volume fan (probably only slightly more than the stove top powered stove) was well worth it. If I had a stove in an open area, I'd have one of those stove top fans - you only need small gradual movement to make a very large difference. The gradual push of the air around our "circle" in the downstairs of the house rose the far side temperature almost 10 degrees. And garnered comments from relatives "what kind of silly person uses a fan in the winter...do you need to cool down or something?"
A friend did exactly this - he used a fan from an ATX PSU. His stove was in a very confined space in what had been a fireplace intended for a gas fire - he thus got little or no convection around his stove, and the fan was a small help until the surrounding masonry started to warm up. I think that if your stove is installed to allow proper convection, then you would get less benefit from a fan - except perhaps from a de-stratifying effect...... I have at various times thought about rigging up a small and quiet electric fan in the fireplace and seeing what effect that has, in fact thats the thing that might work best?
Steve.
