woodfarmer":2gb6d111 said:
It was Whitworth himself who experimented with thread forms and found the rounded thread which we now call Whitworth to be the strongest. The American UNC/UNF V threads are -much- cheaper to make and 60 degrees is also cheaper to produce. When cutting threads on a lathe, the sharp point is very easy to make
but ideally they should as said be flat topped.
Sir Joseph Whitworth was the first manufacturer to 'STANDARDIZE' the combination of diameter/tpi which eventually became BS84. Prior to his work, each manufacturer simply made whatever they thought would do the job in hand which made interchangeable components and after-market repairs quite difficult.
When I mentioned 'sharp Vee' I made a point of specifying 'in the root' - sharp point on the crest is, as you say, very easy! However, if you were to machine to a sharp point crest then the thread would be too thin and the effective dia. would be undersize.
