Which bench grinder for woodturning chisels?
CJCaptainBlack
New member
8 Sep 2017
Gloucestershire
Hi,
I've recently bought a second hand lathe and some chisels but need to sharpen them!
I've been doing some research but most of the recommendations I can find are a few years old and the product links don't work.
I have found two solutions and hoped for a bit of advice.
This one already contains a white stone which I think is best:
I can't post links but Googling this should work: record-power-rsbg6-6-bench-grinder-with-40mm
This one has a belt sander which I read was also a good option (I think I read it was easier to use on chisels), or I could change the grey wheel for a white one:
cbg6sb-6in-bench-grinder-with-sander
Thanks,
Chris
The Record Power six or eight inch with white wheel and a home made rest will be more than fine. If and when you feel like pushing the boat out a Robert Sorby Pro-edge.
