sploo":3mdf2ptx said:
Are the blade teeth well in front of the side guides (i.e. not damaging the teeth and blunting the blade)?
Photos may help.
+1 on the above, how are you setting the side guides in relation to the blade ?
The guides should be very close to the blade sides but not actually touching.
The side guides should be far enough back behind the gullets of the teeth so that when pressure is applied to the front of the blade when pushing the wood forwards, the gullet of the teeth still remain in front of the side guides, otherwise the side guides will take the set and sharpness off the teeth.
I wonder if this is what is happening as in your picture the bottom left guide looks like it has been ground away by the teeth near the outer edge ?
There are guide sets both above the table and below the table usually, are you setting the below table ones similarly ?
Cheers, Paul
