Quantcast
Where to get hold of an anvil?
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
I want to do some blacksmithing and would like to get myself an anvil - not easy to find - any suggestions? TIA W2S
AJB Temple
Finely figured
13 Oct 2015
Tunbridge Wells
There are usually loads of them on eBay. Prices all over the place.
Depending on what you are doing, you may find it best to get one with a cast iron stand as well as a heavy anvil. Forge work needs heavy gear. I am on the hunt for one myself as it happens. But I am not willing to travel far.
adidat
I will not buy anymore tools...
6 Nov 2009
sunny somerset!
Lots on eBay, most require re mortgaging the house though!
Adidat
Lons
14 Feb 2010
Northumberland
I have a couple of small ones but use a 600mm length of very heavy iron I beam for heavy stuff. keep it under cover outdoors and just dress off the top occasionally with a grinder, works well.
DiscoStu
24 Mar 2014
Lee on the Solent
Machine mart sell them cheaply. Not sure about the size of them or quality.
LancsRick
30 Dec 2011
Lancashire
Reclamation yards are a good place. It's worth putting a lean-to roof on your forge too, not just to protect it but to keep the weather off to an extent.
marcros
11 Feb 2011
Leeds
phil.p":1bwzk3aq said:
Don't be tempted to buy cheap - I've a 5kg Draper one for jewelry - the top marks through sheet copper.
The Rutland's one is equally as soft.
Jacob
7 Jul 2010
Derbyshire
ebay. I sold a nice old one recently for £100. Bargain.
Phil Pascoe
29 Jan 2012
bourbon":t702rjcg said:
https://www.anvils.co.uk/about-us.html
you won't need to fettle them then. And get a turning hammer and you won't mark your work too much. Do you want a gas furnace or coal?
You'd probably need to use them professionally to justify the cost. :D
Hitch
28 Jan 2006
Somerset
A 5kg anvil isn't much good for forge work, you'd want at least 10x that... unless you are doing very delicate work.
heimlaga
27 Sep 2009
western coast of Finland
If you are a good scrounger and repairman a decent set of blacksmith's tools do not need to cost a fortune.
I paid 20 euros for my 40 kg Lokomo anvil at a local scrapyard.
The edges were totally destroyed to the point that the anvil would have been useless for anything but very rough work but I preheated the anvil to 150 degrees celsius using a blow torch and built up new edges with my stick welder and some 3,2 mm Elga Selectark HB61R electrodes. Then I ground the built up areas to shape with a big angle grinder.
I learned this repair method from an old blacksmith. He said that theese repairs aren't as strong as the original anvil was but they are strong enough to last a decade or more of professional use and then the same anvil can be repaired again and again infinitely using the same method. A decade of professional use equals a couple of centuries of hobby use.
Before this anvil I had a smaller one on which I had resurfaced the entire top with theese hard welding rods. My uncle bought it from me and he still uses it occasionally. I think I paid 35 euros for it when I bought it from a local antiques dealer.
Keep looking and keep asking and one day you will find a cheap yet good secondhand anvil.
Cheap new anvils from china are made from cast iron with no hard top. This means that they get dented by every hammer blow and after a while they start cracking just like cast iron always does when beaten with a hammer. It is a soft and brittle material after all. Totally unsuitable for making anvils. Of cause they are impossible to repair.
The anvil stand doesn't have to be made from cast iron. Around here the traditional anvil stand is just a suitable piece of a big tree trunk. The bigger the better. Mine is around 40 or 45 cm in diametre.
I suppose the Brits started using cast iron stands when they ran out of big trees.
My portable forge didn't cost much either.
I got it for free from an aquintance who said it was beyond repair. It had stood indide a cow shed with a leaky roof that collapsed on top of the forge some 50 years ago and rotted away so when I first saw the forge it was standing under a birch tree on the edge of a field where to cow shed had once been.
Getting it apart without further damage was the hardest bit but once that was accomplished I could straighten the frame and the crankshaft and rivet on a new top plate and make a new shaft for the blower and put everything back together with a new drive belt.
Keep going!
