I agree with what has been said. Also, there is a difference between roughing cuts and finish cuts. Roughing is getting all of the waste out of the way, and they can be heavy and coarse, and will lead to more tear out. As you get closer to final form, your cuts get lighter and more gentle so there is less tear out. Roughing cuts are more of a scraping cut, and finish cuts are more of a shear cut with the tool, either a gouge, or a scraper held at an angle to the wood. I can get equally good cuts with a freshly sharpened gouge or scraper (I do prefer a good burr on my scrapers). Your finish cuts should result in little whisps of shavings floating in the air. Of course, some woods are more likely to tear than others, and oak is one of those.
Dry wood will tend to tear more than green wood, and as near as I can tell, this is because the wood is lubricated with the moisture that is in the wood. Wetting the wood helps this, just get it damp with water, oil, or sealer, let it sit for a minute or two, then use very light cuts to remove the wet stuff. If the tear out is bad, this can take several applications. Getting the wood wet doesn't hurt the wood because you end up cutting away all of the wet stuff.
robo hippy
