wax oil
clive griffiths
UKW Supporter
12 Aug 2020
south wales
Hi.
For many years i have been using sanding sealer (2 coats) and a wax finish , I have now started to use wax oil , is it o.k. to clean off this kind of finish and wax oil over the top.
Yes it will be fine. Remove the wax with white spirit and cut back the sanding sealer with 240g you can then use the wax oil over that. You can also wax over the wax oil once it has cured.
