Wardrobe build
Nathaniel G
New member
20 Jul 2019
Bristol
Hi everyone,
I am new to woodworking so I have little experience in choosing wood, however I am planning to build a wardrobe as I don’t like the flimsy ones that they sell in next and other places like that. I’m thinking about using plywood as the main carcass. What type of ply do you think I should use? Is the stuff that B&Q sell good enough?
Thanks for any help
Nathan
AndyT
24 Jul 2007
Bristol
I thoroughly recommend that you read along with Steve Maskery and follow his detailed account of the one he is building.
topic117121.html
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Ply quality varies hugely and until recently, I would never go to the shed to buy ply other than for shuttering. However recenty i need a small quantity for an upholstery job that would never be seen. B&Q had some hardwood faced ply that had very few voids. I did a mini review here http://www.thewoodhaven2.co.uk/viewtopi ... 31&p=54794.
Yesterday I was cutting some ply for a friend and he had got some "hardwood ply" from wickes. I was very impressed with the quality. The outer faces were beech and it cut very cleanly with little splintering with a combi blade.
Iwould suggest you always select the sheets when buying from the sheds.
mbartlett99
10 Aug 2010
Hitchin, Hertfordshire
You definitely didn't got to the Letchworth Wickes - not a single flat piece in the building although the faces were good.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
My mate brought the plywood to me for cutting so I don't know how many he went through to get what he purchased.
The greatest bow was about 1.5 mm in a 4 foot sheet that I noticed when making the scribing cuts.
Logger
28 Feb 2015
Badminton
Depending on your location, you may be better getting the ply from a decent timber yard. I use either avon plywoods or Robbins timber, both near bristol
Depending on size and number of sheets you need, they may give you discount, and it will be better quality than b and q. There should be similar places throughout the uk to purchase boards.
I made a large wardrobe for a customer recently, but went with 19mm oak veneered mdf (with solid oak door frames).
Still got some finishing off bits and to correct error with one door (customer hasn't commented, but i can't live with the error)
Good luck!
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
There seems to be a gremlin hiding in the utility room, top left!
Nice wardrobe though.
Fitz.
Logger
28 Feb 2015
Badminton
Well spotted. No idea what it actually is, but definitely looks like a Gremlim! Glad i was unaware whilst building the wardrobe!
Nick
