Hi all,
Im stuck.
For a while now, Ive had my wadkin 10AGS. Its never cut well. (Burning when ripping) So today I decided that I would do it properly, (align the blade to the mitre) which is fine I did that with the blade fully extended up. Between 0.01 front to back. (Metric)
The issue is when I lower the blade, the blade becomes out of alignment. Between 0.28 and 0.35mm out of being true. (Metric)
So I thought, it must be the trunnion. But I cant see anything in the saw or on the internet that would adjust it to true it up. Does anyone have any ideas?
I should also note, that spindle mounting casting has been welded, pretty good job but im a but suspect that it might, might be warped.
Thank you
Sent from my SM-G950F using Tapatalk
Im stuck.
Thank you
