Vaccum pump
bertterbo
18 Apr 2022
North Wales
I've got one of the cheap Amazon vacuum pumps, 0.8pa, 3 CFM. It works great, and gets a vacuum of at least -29inHg, which secures pieces to my wood turning vacuum chuck just great.
However ... when the piece has tiny air gaps in the grain, a good suction cannot be formed, and I only get about -10inHg, which isn't enough to turn with.
If I upgraded to a 9cfm or even a 12cfm pump, how much of a difference do you think I would see?
If you can't get a good suction with a 3cfm pump because of air gaps in the grain I would suspect you will get the same issue regardless of how much suck you apply, to a vacuum pump a leak is a leak, the bigger CFM pump will just show the leak quicker.
I was thinking that a higher CFM could hold a better vacuum even with a leak. As its removing more air quicker (than a lower cfm) than being lost due to the leak.
I suppose the only way to find out is buy a bigger pump and see. Good job they are a lot cheaper than they used to be, I used to do refrigeration work in the 90's and the vac pump I used was over £300 then, now they can be found well under £100.
Your thinking may well be valid. Let us know how it goes with the bigger pump.
A bigger capacity pump is not the answer. The tiny flow through your seal is insignificant compared with the free flow rating of the pump, be it large or small. A larger pump may well pull less vacuum than your present one. A higher quality pump may improve the suction but that could be an expensive solution.
What you need to do is improve the seal. I would suggest filling the grain where the chuck makes contact.
Brian
Well, a higher CFM is around £120 for a cheap one and upwards of £300 for a better quality one. So risky 😬
Brian
Can't really fill the grain as I'd be cutting away the material being filled.
Random thought but if the work is porous and on a vacuum chuck, why not slap a coat of sanding sealer on and let the vacuum pull it into the wood. Hopefully it will seal deeply enough to allow you to keep turning
