Quantcast
Useful knots to learn.
Rorschach
Agent Provocateur
6 Jan 2016
Devon
I am rather rusty since my scouting days. I am setting myself a goal of learning a selection of useful knots to expand my current knowledge and also to be able to teach my nieces and nephews.
I don't use knots an awful lot in day to day work so I will be forcing myself to practice regularly.
So what do you think is a good list of knots to learn? My list so far is below and I would welcome any input as to knots you find useful and why.
Bowline
Constrictor Knot
Figure 8 (knot and loop)
Versa-tackle (an improvement on the truckers hitch I think)
Highwayman's hitch.
EDIT: Note I have left off what I would consider common knowledge knots like reef knot, granny knot etc.
frank horton
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
Thats a good start,
I'm still useing the knots I learned in the Scouts........and a few more.....
I'm still trying to master the spliced end and an eye splice.......hahaha....
I'f I can find it I"ll post it up, it's a photo of my uncle who used to splice ropes and steel wire in the merchant navy....
the picture shows him back splicing a wire rope as thick as ur thigh....spikes and sledge hammers....
Rorschach
Agent Provocateur
6 Jan 2016
Devon
A clove hitch - probably one of the most useful hitches of all.
Now that's one I do know how to do, but I haven't found a lot of use for it. If I want it to be strong I use the constrictor, which is almost identical to a clove hitch. But if I want it to be easily removable I use something like a highwayman's hitch which is just as quick to tie.
Yojevol
Wooden tit be nice... ♪♪♪♪♪♪
29 Jan 2017
Cheltenham
Sheepshank - used for shortening a rope
Reef knot - tying 2 ends
Granny knot - for when you've tied a reef incorrectly
Fishermans knot - for wet rope or line
Hangman's knot - for when you want to...........
Sheetbend - for tying unequal sized ropes
That should keep you going for a while
Brian
MikeK
Moderator
Staff member
Moderator
9 Apr 2017
Gernsheim, Germany
One-handed bowline - I had to learn that in the military, but never had to use it. This allows you to hang on with one hand and tie the rescue rope with the other.
Rorschach
Agent Provocateur
6 Jan 2016
Devon
Brian
Reef knot is on my already know list but certainly a useful one and better than the granny knot. Surgeons knots a useful variant as well.
I have done the hangmans knot in the past, of course never used for hanging it seems. Probably not a useful one in everyday life though.
Will look at sheetbend and fishermans knot. I will leave out sheepshank, never needed to shorten a rope in life my life, I just cut it, rope used to be expensive I assume to have use in the past.
Dr Al
11 May 2020
Dursley, Gloucestershire
I haven't got much to add to this, but I'm going to say a special thank you to @Rorschach - I've been using the "Versatackle" knot for years and I use it for all sorts of things, but I never knew what it was called! Now I do!
Trainee neophyte
[Insert witty and amusing title here]
12 Apr 2019
Greece
Get a short piece of rope and use it to practice. Endlessly. It's all muscle memory, so the more you tie, the more likely it will stick. Practice whilst drinking tea, reading the paper etc. It will drive the rest of the household nuts, but is quire therapeutic. My favourite is the sheep shank, but I never use it in anger. Bowline and truckers hitch get used almost daily, and I quite like the alpine butterfly loop/hitch thingy, but never need that, either.
Rorschach
Agent Provocateur
6 Jan 2016
Devon
I only re-discovered the name quite recently. It's a knot I learned in my teens for putting up tarp ridge lines as it was much better than the usual knot used for guy lines. I forgot the name though and then I found my old knot book again and had to look through every page until I got it.
Rorschach
Agent Provocateur
6 Jan 2016
Devon
This is another know I used on tarp lines, the Evenk slippery hitch (similar to a Siberian Hitch, personally I think it is slightly easier to tie thought maybe not quite as secure) learned as a teen from a Ray Mears show. It's so fast to do and surprisingly secure I have found.
Garno
Grumpy Old Git
21 Oct 2017
Dronfield
Half Hitch
Double Clove Hitch
I noticed Clove Hitch has been mentioned
Those three aare used a lot.
Rorschach
Agent Provocateur
6 Jan 2016
Devon
Half Hitch
Double Clove Hitch
I hear that a lot about the clove hitch but I mentioned above I don't rate it much. When would you use one?
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Alpine Butterfly loop and the bend, very uesful for making rope bridges or grab handles
Rorschach
Agent Provocateur
6 Jan 2016
Devon
Tethering animals, tying up boats ...
Would you actually use a clove hitch for that though? Both of those applications are for "jiggling" loads that would work a clove hitch loose quite easily, especially on a smooth tying point. A highwaymans hitch, the Evenk hitch or Siberian hitch mentioned above are just as fast to tie and would be far more secure surely?
Trainee neophyte
12 Apr 2019
Greece
I've been wondering why I don't use a clove hitch, and it's because I would always do a round turn and two half hitches instead. The highwayman hitch is fun, but I would never tie an animal with it...know too many horses who love tugging on the end of ropes.
