studders
Bought a new Freud blade for my new TS200, good price too. Last night I set about fitting it.
Things didn't start well when, following the instructions in the 'Manual', I use the term loosely, I tried to undo the bolt by turning it clockwise, it supposedly being a lefthand thread; it isn't. :roll:
A few cuts to the hand later, just exactly how are you supposed to stop the spindle turning to undo the bolt?, I had the old blade off.
Fitted the new blade and set about adjusting the riving knife. Got it where I wanted it and started to tighten the nuts that hold it on and..... one of the nuts tightened, the other just kept spinning.
I hadn't put that much pressure on the spanner so I was a little confused why the thread appeared to be stripped, I soon found out why.
The welded studs are about an inch long, on this particular saw there is over a quarter of an inch of shims :shock:
add those to the backplate thickness, the kinfe and the heavy front plate and there is only a few threads left for the nut.
After much thought about how to secure the riving knife the realisation dawned on me that I now had a major strip down of the saw to do to extract the bracket and repair it.
Happy? Me?...... Not really.
