StevieB
I need to remove a radiator, and one of the valves is a TRV. Does anyone know if these are sealed units? I can take the cap off the other end and do up the gland nut as usual, but the top of the TRV does not seem to come apart. I can turn it to 0 which stops the radiator getting hot and I therefore presume stops water flowing through the rad. If I undo the nut between the radiator and the valve when it is set on zero will that be OK or is SWMBO going to look at me like I am a complete silly person?!
Cheers in advance!
Steve
Cheers in advance!
Steve
