wrinkly1":3lomxyru said:
... only the TRC001 is mentioned in the blurb.
The TRA001, TRB001 and TRC001 are essentially the same router, the codes were intended initially as international separators. The only physical differences in the TR model range is that most come with a "press and turn" twistlock to change plunge modes, others with a push-button mode change (both situated in the right-hand handle).
You'll need four machine screws - ¼" UNC - around ¾" to 1" in length to mount the router to an insert, as the baseplate screws are designed only to hold the thin black plate on and not to mount the router. Screws will not be supplied as part of the package, as the router mounting (the two domed-headed bolts) are specifically designed for twistlock mounting in Triton's own router table.
Let me know if you have any problems, as I've got some in stock. My review of the router is
here. I also wrote a page on the maintenance and dismantling a while back, to be found
here if it's any help. It will as least give you an insight into the workings of this unique tool. If you have the push-button plunge mode changing mechanism, this is identical to the one fitted to the smaller router, the MOF001, details of which can be found
here and a comparative review
here.
Please take the time to sit down with the router and have a thorough read through the manual before firing it up. You'll be sure to get the very best from it that way. Remove the plunge spring for inverted (table) use and leave the cap off as this allows dust and debris to fall straight through and not become compacted in the cap, preventing fully raising the router in some cases.
Any other questions, please fire away.
Ray
