Brucio
I've been reading ( a nasty habit I know) about "top loading" scrollsaws, where if you want to make an inside cut, you release the blade from the bottom clamp, lift the top arm, which apparently drags the blade upwards, and you insert the blade into the top of your inside cut hole.
Whereas us normal plebs have to make do with trying to insert the blade into the bottom of the hole.
My question is: how do you get the bottom of the blade back into the bottom clamp?
You can't see down from the top, because your wood is in the way.
You can't see the bottom of the blade, unless you've a great hole in the side of your saw, big enough to get your fingers and some kind of clamp tightening gadget in at the same time?
I can't believe the top arm will lower the blade EXACTLY into place in the clamp!
And yet, people must be buying these things....
Bruce
Bruce
