I had a great day in the workshop today!
Have a look at what I got
Numatic wet and dry vacuum
SIP extractor
Both of these cost me.....
Nothing, zip, zilch, nada, zero!
Can you believe it?!?!?!
I acquired them because they were apparently not working, so I thought I would take a shot at fixing them as they would be awesome for my uses and if they cost £50 each to fix then they were still a good deal!
Well I got them home and put two new plugs on them ( the originals were cut off for some reason), plugged them in to see what I had to work with and what do you know..... They both fired up first time with no issues at all!
Chuffed is an understatement!
The only things that are needed are:
A new filter for the numatic
A longer length of hose for the extractor.
Both of these will cost pennies to sort out which is a bit of a result
Just thought I would share my finds with you guys!
I am here: http://maps.google.com/maps?ll=51.669210,-4.055708
SIP extractor
