devonwoody
I purchased a board of London Plane last week and started on a box in addition to the block box also underway.
The board of LP was 12" wide and rough sawn 60mm thick in spots. So I have decided to cut my carcass boards down the thickness which then should produce almost quartersawn timber and I believe known as Lacewood.
The picture below shows a 12mm thick strip but is only 52mm wide. (and this means I cannot get the full depth my tissue boxes need.)
The second photograph I have added a contrast strip top and bottom of American Black Walnut to make up depth required.
