Timber identification help.
mickster
21 Oct 2007
Oldham, Lancs
I wonder if someone can ID this timber for me please?
I have done some searching, but haven't yet come across anything stating the type of wood likely to have been used.
It is a surplus piece of reclaimed timber, a slate-roofing spar/rafter, which I have had for about 10 years and hadn't found a further use for it...until I recently got my mini-lathe.
Pics of a cleaned up offcut below:
End grain-
http://img.photobucket.com/albums/v47/M ... 0_0164.jpg
Close grain & knot-
http://img.photobucket.com/albums/v47/M ... 0_0166.jpg
Coarse grain-
http://img.photobucket.com/albums/v47/M ... 0_0168.jpg
Thanks in advance,
Mick.
It looks like a piece of old growth pine, rather different to the fast grown whitewood you find these days. Could be one of several pines or maybe Douglas Fur but that is a little more redder in colour usually.
Jason
Looks identical to the pine I got hold of from a roof of a house built in the 30's. I agree to one of the previous replies totally different to todays, great deal harder, clearly grown slower.
Being reclaimed timber lends a few clues, and some speculation on my part. Many years ago a lot of Russian red deal was used in the UK. If you look at the growth rings, even the wider spaced ones are quite close suggesting slow growth, and a cold climate. The tight rings suggest a period of even colder seasons. If memory serves me right, the Port of Archangel, is unaccessible for six months during winter. It's b***y cold there. I've seen this in old mouldings and samples we have had to copy many times.
The band of tight rings is over an increase of about 26mm in radius and contains roughly 67 rings before they start to increase in width again. The next band of 7 wider rings continues before narrowing again for 6 rings. The remainder have less drastic changes.
The widest ring is roughly 2mm.
And there are those who think climate change is a new phenomonen. :roll:
I could try to search meteorological data for similar historical patterns, but I'm not that desperate for a positive ID. :lol:
