Mark A
Hi chaps,
I'm after advice re tiling patterns.
I was planning to start tiling today, but figuring out the orientation of the tiles is proving to be more complicated than I first thought. I started to measure out for a 1/3 brick bond, but the walls are in such a bad shape I'm concerned the pattern will accentuate the dips and bumps. Why don't I just level the walls? Because it was boarded out a few months ago by "professional plasterers" and the ******* arseholes have done a truly appalling job. The walls have been dot and dabbed with barely enough adhesive to hold the boards up (never mind supporting the weight of the limestone tiles which we had hoped to use), they are far from square in the corners and the surface undulates... I was away at the time, otherwise I would have battened the walls properly myself. I've done all I can bar pulling it down and replacing, which is not an option. Okay, that's enough moaning...
I'm now considering setting the tiles vertically; however I don't know how that will look around the bath as there's 580mm from the edge of the bath to the window above and the tiles are 600. I could add a border on top to finish it off, though I think a single tile will look naff.
I'll see if I can draw something to explain my dilemma.
Cheers,
Mark
Cheers,
Mark
