Quantcast
Thicknesser Specs?
woodpig
17 Sep 2011
Dorset
Whats the shortest length piece of wood you can put through most thicknessers and end up with something usable? I often have small pieces of wood that I'd like to use up.
condeesteso
10 Mar 2011
Sevenoaks, Kent
Exactly - a consise response from Davey but that's it. MDF is handy to stick the little bits to as it is reliably consistent thickness. It's also really handy for planing very thin stock (a few mill easily).
woodpig
17 Sep 2011
Dorset
Any tips for separating the wood afterwards though without damaging the surface?
DaveyP
2 Aug 2011
Dumfriesshire
Just gently pull it away
But If there was an issue with removing from the tape then a little something to soften the adhesive like meths (not the drinking grade) should do the trick
