I changed the blades for the first time on my Metabo 260C thicknesser this week. Since then, I've started getting a couple of inches of snipe on the leading and trailing edges which I never had before.
Would this be caused by incorrect setting of the blade height? I carefully set the height using a straight piece of wood and measuring the travel when I rotated the blades by hand, but should I trying setting them lower? Or higher? Or have I set the blades at different heights? I don't know how accurate it needs to be....
I don't know if its relevant, but I checked the flatness of the bed today for the first time since I bought it, and I notice there is a slight curve to it. It's a cast iron bed, but if I lay a flat metal rule edge on it, there is light at the centre. Would that matter?
Thanks a lot..
Thanks a lot..
