Dalboy
This is just the start of this piece and I thought that as I mentioned in another post about work being posted I should at least put something up even if it is only a mini WIP.
I did start with a sketch with this one but due to a small detail that did not look right I went and cut another piece of wood to return it, but not wanting to waste the piece I decided to finish the base with a little modification and was going to put it to one side to make a new top well it has turned out better than expected and when I offered the top to it I liked what I saw.
The first photo's are of the top with it marked out ready for some cutting.
Then there is the base unpainted with the modification sorry did not take any before shots.
Then there is one with the first coat on and as can be seen needs more work as the base will be a high gloss so as you can imagine a lot of prep work nearly 3 hours getting the finish I wanted before the paint is applied without this any blemishes will show like a sore thumb.
The next stage is to rub back the black and see if there are any bits that need a little filling like the grain. This was the only wood I had that was the correct size as it was either the right cross section but not long enough or too long but not the right cross section so Ash it was.
More tomorrow to allow the first coat to dry.
