The line
A
Anonymous
Guest
Hi all
Finally did some scroll saw work the other day and found it very difficult to cut a smooth curve up against the line. I was cutting a 'smooth' curve in 18mm MDF.
So, is it down to practice? skill? better blades? technique?
How do I cut in the direction i want along a long, smooth curve without wandering?
Thanks for any advice
Practice and a good sharp blade will certainly help, as will a slow feed rate. In 18mm MDF the feed rate will need to be quite slow. The other option is to cut to just outside of the line and use a drum sander to take it back to the line exactly - you would be amazed how often that is done!
Steve.
Tony,
In my experience the long smooth curve is the most difficult cut with a scrollsaw.
It does get easier with practice, or as Steve has said, cut outside the line and and back (that's what I end up doing half the time!).
Regards
Gary
