I retiled mine last year and I removed the Mira surface mixer and just fitted 15mm compression caps on the existing chrome nuts 15mm compression caps - Google Search
Your shower may be 15mm compression ends but sometimes the mixers have a 3/4" offset tapered fitting. If yours is not 15mm compression you could take the mixer to a plumbers merchants to see if they have anything to cap it but it will probably be a bit hit or miss using half of one fitting with the same taper and a BSP cap. Some of the old traditional ground faced 1/2" radiator valves had a similar set up and may fit.
