Renovating a Bungalow bathroom for my mum, and will be fitting a new bath or shower. The bathroom is tiny, being only 1600mm square roughly.
Part of internal wall (1950s breeze block type) wasn't built square so a new bath or shower (not decided yet) won't fit nice. The old bath had a large gap at the end which was covered with tiles which looked awful and I don't want to repeat that, so I need to square the wall somehow. I can't lose too much space as a 1600mm bath only just fits in currently. (although has a 30mm gap on the left side of the end)
I have attached a diagram to help visually, but basically I need to pack out 30mm over 800mm so a bath or shower tray will fit in nice and square.
Should I use some battens (20mm on the left, and 10mm in the middle, and none on the right) and then attach aquaboard or something, or perhaps use render? Or couple of coats of bonding before skim? It's 30mm, so fairy deep so concerned about whether Bonding or Render will be OK at that depth.
Unsure if it will be tiled or showerpanels, but want to ensure that the corrected wall will be able to hold heavy tiles if needed.
If it helps, the whole bathroom has been stripped back to the original render as the skimcoat was falling away, and will be skimmed all over. Just want to know what to do with this angled wall before I get the plasterer in.
Any ideas would be great. Thanks folks.
![PXL_20231213_160600529.jpg PXL_20231213_160600529.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/152/152672-PXL-20231213-160600529.jpg)
![PXL_20231213_160402388.jpg PXL_20231213_160402388.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/152/152673-PXL-20231213-160402388.jpg)
