george4471
New member
Hi,
Since leaving school back in the early 1980's with very basic woodworking skills I've now taken on the challenge of creating a number of ledge and brace doors for our house. I've successfully completed a small door for our pantry using 12mm tongue and groove and intend using either the same or thicker wood for the other doors. What I'd like to do is hide the screwheads on the back of the door without filling them with filler. Ideally I like to put some dowel in to neaten it up.
What I'd like to know is what tool do I need to enable me to drill the smaller hole for the screw (normal 25mm wood screw) but make it wide enough for me to tap in a piece of dowel ? Is it as simple as drilling the smaller hole first with a 4mm bit then using a wider bit afterwards - ensuring I don't go all the way through the wood !!!
Look forward to hearing from the experts !
regards
martin
regards
martin
