Barry Burgess
The current issue of ShopNotes has an article on table saw moulding heads.
Is this a similar no no as is the dado cutter??
Raincoat indeed - I'll have you know it's a genuine locally made copy (read cheap Yorkshire knock-off) of the famous Barbour waxed thornproof jacket........ Although I've always fancied one of those long "Ranger" type thornproof coats :lol:Barry Burgess":20roj9va said:We will have to wait for the man over six feet in a raincoat who has been seen at the top shelves at the news agent(his description not mine)
Now you know why they're no longer readily available......misterfish":1hf8p7pr said:Mind you, having seen Norm using one of these things I thought it looked as if extreme care and caution would be advised.
Mr_Grimsdale":1hf8p7pr said:A router is a very limited little gadget compared to real machinery like table saws and spindle moulders believe me.
Mr_Grimsdale":1tfbgyms said:Router is a very limited little gadget compared to real machinery like table saws and spindle moulders believe me.
cheers
Jacob
Mr_Grimsdale":3ta95hyd said:I meant router in the normal sense i.e. essentially the familiar hand held machines which everybody seems to have - amost no relation to your example.
cheers
Jacob
Scrit":2maembrs said:So my little pin router is limited? :? :shock: :wink:
and at 1350kg it's about twice the weight of an industrial spindle moulder...... (and murder to move)
Scrit
Yes, I know you did. Only joking . But as you know in the absence of a spindle moulder a modern large portable router can be pressed in to service to cut mortices and tenons, mould edges (including around tight radii), recess, dowel drill and biscuit slot, amongst a host of other things. The initial outlay isn't so enormous that it is out if reach for many people and it doesn't take up so much space. Yes, I wouldn't do without a spindle unless it was forced on me as it can do things in one pass that would take an age and many passes withna router, but I still feel a router in a table or hand held can run rings round a shaper head in a table saw, and declining American sales of the shaper heads might be seen as confirmation.Mr_Grimsdale":2ebzq8tr said:I meant router in the normal sense i.e. essentially the familiar hand held machines which everybody seems to have - amost no relation to your example.
