The Sedgwick MB planer thicknesser boasts simpler and more robust engineering, exceptional quality casting, both for the machine's overall thickness and the fabricated base. This inherent sturdiness makes them superior machines, significantly reducing vibration and yielding a superior finish. What sets the Sedgwick MB and CP apart is their dual-motor system that powers the spindle and feed rollers. Additionally, the planer tables, thicknesser table, and fence are all crafted from high-quality cast iron. This ensures that nothing will bend, twist, or shift when the machine is set up for operation.
What sets the Sedgwick MB and CP apart is their dual-motor system that powers the spindle and feed rollers. This straightforward design is a testament to the machine's engineering excellence.
Sheartak offers spiral cutter heads equipped with indexable carbide inserts. Featuring four cutting edges, these carbide inserts boast a lifespan 40 to 50 times longer than high-speed steel blades. Positioned at an angle to facilitate shear-cut feeding, they effectively eliminate tear-out and yield a superior surface finish. The spiral cutting design significantly reduces operational noise and facilitates easier dust extraction. Sheartak's spiral cutter heads contribute to restoring the former excellence of Sedgwick machines. Explore further details at https://www.sheartak.com/sedgwick.
![sedgwick-mb308-planer-thicknesser.png sedgwick-mb308-planer-thicknesser.png](https://cdn.imagearchive.com/ukworkshop/data/attach/155/155417-sedgwick-mb308-planer-thicknesser.png)
