Before cutting today, I decided to check the alignment on my table saw and discovered that the blade appeared to be significantly out of alignment to the mitre sled track.
I checked it by setting the blade vertical using an engineers set scquare and happy with that.
With the alignment, I checked the front edge of the blade against the mitre track, set the set square, then checked the rear and the gap is quite easily visible, even in the photo attached.
I have looked under the saw bed and taken some photos..............I wonder if anyone can offer advice on how to get the blade alignment correct.
