SU: How to draw a mushroom shape knob quickly
CYC
23 Jul 2003
Kildare, Ireland
Hi all,
Can someone give detailed instructions to create a mushroom shaped knob in sketchup please. Every furniture I design, I alway have to fiddle to make one :oops:
Thanks in advance.
Hi CYC,
Well you could try downloading mine from the Warehouse :)
But if you want to do it yourself:
Draw the vertiacl centreline
Draw the base circle
Draw the curved profile between base circle and centre line - this will give you a profile surface to revolve.
Select the base circle
Select Follow Me
Click on the profile surface
Voila!
If the knob is small, you may get a void at the top centre. If this happens, create the knob 100x too big, then scale it down by 10 and again by 10. SU struggles with small surfaces (it was designed as an architechtural tool), but this is an effective work-around.
HTH
What Steve said, graphically.
