Roy, the tyres are ok now that ive cleaned them,there was a line of sticky gum or something around the middle of the top tyre forming a slight ridge.I think the college where the saw came from must have had a 1/4" blade on it since new.I bought a blade from axminster ,just to try it out as i was ordering something from them at the time.Its a 3/4" blade.Digit":2bojmcaj said:Bob C. One of the reasons for wander, especially with a narrow blade is the condition of the tyres.
They are supposed to be 'crowned' so that the blade tends to climb to the highest point.
Wear on the tyres often results in the loss of the 'crown' or indeed grooves and the blade can wander as it tries to climb to the highest point.
Also check that one or both wheels are spinning without a warp in them.
Reg, I can probably turn you some round ones if you get stuck.
Roy.
Steve,The blade is just a 3/4" one from axminster to try the saw out.The saw is a 3 phase Jet JWBS-18 that i mentioned in another thread about either changing the motor or getting an inverter.I went the inverter route after finding one cheap and it seems to work fine.The tracking is obviously off somehow,i intend getting some better blades from Dragon or one of the other suppliers. Another thing i,ll mention is that there is quite a bit of vibration in the top half of the saw that i dont particularly like.I dont really want to bolt the saw down to the floor as i need to move it out for cutting long pieces of stock.I dont know if the tracking can cause this vibration or not??Steve Maskery":37maam9s said:Bob
I would not be happy with 1/16" variation in line.
The most common problem is the condition and quality of the blade. Few bandsaws come with a good blade. Various people on here rave about Dure-Edge (including me) Hamilton Edge (including me) and Dragon (I've not tried them yet).
Start with a good b lade, get the tension right, sort your tracking out, compensate for drift and you should be fine. If you have a collection of GWs I did an article about 18 months ago on how to set one up. If you don't, send me your email address I'll see if I can dig out the original article.
BTW, if your bandsaw blade was cutting a groove across the face of the rear thrust bearing, then either it was set way too far forward, or it was gummed up and unable to spin. If it's grooved you have little option but to replace it.
Steve
Yeah Roy they look ok to me ,ill try and take a picture tomorrow without the blade on it ,and you can let me know what you think.Digit":3dgfpvq1 said:Do they have a decent 'crown' on them, if they haven't the blade will always wander?
Roy.
Might be worth checking,thanksDigit":yqhc3cqb said:Sounds like you might have a duff bearing up top Bob.
Roy.
bob_c":2hz22pkv said:The blade is just a 3/4" one from axminster .
Steve Maskery":44yhmwhf said:Bob
