Got a smashing piece of elm - a vertical slice through two big burrs and the edge of the trunk. I've braced and treated the back and am trying to get the front smooth and clean. There's some dark stains and milling marks I can't shift even giving it some well with 60 grit on a ROS. The surface isn't very flat.
What's the best next step? Just keep going with a sander? Or should I give it a gentle plane first. I don't have a hand plane or belt sander - so it's ROS, detail sander or an electric plane on very low depth moved gently.
Also, at what stage should I treat the front? I was thinking once the main sanding is done but with a final fine sand after treating just to clear off any residue. Using clear preservative then going to Danish oil.
Any advice appreciated! Thanks
