Strange Shaped Leg
WESLEYGC
New member
29 Oct 2021
Leicester
Hi Guys,
I'm hoping you guys can settle a bet. I'm making a stool that has a very strange shape leg. Its a 40x40x1000 blank and wants to go from dead square at one end to circular at the other. The leg needs to look like this-
These images show a section all the way up the leg from top to bottom. Each face has a radius ranging from 22mm at the bottom and increasing as it moves up the leg to the square end. My question is, can this be done on the lathe? I dont think you can achieve this shape and on the lathe you'd get something more like in my next set of images.
So I think you'd get something like this and you'd lose that elegant changing radius type deal that I show in the first image set. What do you guys think? There is a couple of beers riding on this so I hope you agree with me!
BTW I have done a reasonable amount of spindle turning and a couple of bowls, but I'm looking to learn more and this looks like a great place to do that!
I don’t think you can do the first leg on a lathe. CNC maybe because you can make the changing radii. You’ll get the second leg. If you did multi axis or offset turning you’ll get a compromise. Hand working can make the first but doesn’t involve the lathe. Have fun.
Thanks for the response. I agree I think I’ll mark it out and use the trusty no5 🙂. Either that or 5axis cnc. When we tried to visualise it I hadn’t 3d modelled it, so that made it much clearer Option A wasn’t achievable on the lathe!
Hi Guys,
View attachment 120752View attachment 120761View attachment 120762View attachment 120763
View attachment 120757View attachment 120758 View attachment 120759View attachment 120760
Witchcraft
Hi Guys,
Wouldn't you just mount it as a spindle, turn the round end to the desired diameter and taper out the cut towards the square end?
Art liestman does a lot of therming jig turning. It would not work. On a therming jig you would always get an arc on the top of the spindle not a perfect square like your first picture shows, and also the end of leg where picture is a true circle you would also end up with 4 arcs not a sphere.a therming jig would give you the second picture. But also the top would be closer to square but still be like the bottom of leg.
Yes you can do it on the lathe, it's called therming and would entail turning on multiple axes using a therming "jig".
This sounds very interesting even if not applicable to my current project. Do you have any useful links to therming related content?
I am utterly inexperienced at therming, but I think Paul is right that it could be done - would it not be possible to achieve it if the blank is offset in the therming jig, so the required square section isn't touched during the turning?
More than happy to be shot down on this one, of course 😳
I started private conversation with therming info. Here is a picture of a therming jig. The idea of a therming jig is you turn more than one piece at a time to keep the balance, as you are only turning one side of the item at a time. then rotate a quarter turn and keep turning until you have turned all four sides.
The reason why you can't do it on a lathe is that the radius at the top of the leg is infinite, it being flat.
I would suggest turning the bottom inch or so on the lathe, to get it circular and centred, and then doing the rest by eye with a hand plane.
I made legs vaguely like these. Not quite round at the bottom. It was about 35 years ago, so I can't remember for sure what I used. I think I planed it to the rough shape then finished off with a hand held belt sander. I took off all the square edges.
The first image made me think of this.
You’re so right. The first image is exactly that. Unattainable.
