Stanley 78
johnfarris
18 Feb 2012
In me garden shed
I bought a Stanley kit 15 for my no 78 as i needed a rod
What i have been sent has a wider diameter thread and will not fit
Using my calipers the thickness of the thread part of the rod comes out at 6.24mm
When i put my calipers in the threaded hole of the plane i get 5.27mm
Can some tell me what size i need
thanks in advance
AndyT
24 Jul 2007
Bristol
I've taken some measurements off mine. After doing so, I realised it's actually the Record version, the 078, but there's a chance it's useful so I'll post anyway.
The rod itself is 9/32" (7.14 mm) diameter. 3" long overall, of which 2 9/16" is plain, 7/16" threaded.
The threaded part is 1/4" and 26 tpi, which is a BSF (British Standard Fine) thread.
Using calipers like you, I get 5.94mm and 5.27mm.
I think that all this means is that we are both looking at a 1/4" size threaded part. You still need to know threads per inch.
UNC would be 20, UNF 28, but Stanley threads rarely match surviving standards.
rxh
2 May 2011
Surrey
The fence rod of my Stanley 78 is threaded 1/4" UNF 28 TPI . The diameter of the rod is 7.05 mm. The overall length of the rod is 74 mm and the distance from the end of the threaded part to the shoulder is 10 mm.
Bod
18 Nov 2013
Wiltshire.
Looking at my Stanley 78,(As to age it's box gives all measurements in imperial,and its leaflet is 78/55)
My measurments agree with Andy's except the threads are 28 TPI, giving a thread of 1/4x28 UNF.
Hope this helps.
Bod.
AndyT
24 Jul 2007
Bristol
At least you know what you want, and that a Record one, while looking very similar, will not fit.
I wonder what the spares kit will fit? Possibly a much newer 78 plane? Isn't progress fun!
