So my stairs are shot. The stringers have largely parted company from the treads/risers, and the whole lot is being held together with numerous big galvanised brackets and lots of screws. Actually they have been for some considerable time now. I knew this when I took up the hall and stair carpet last year to force me to do something permanent about the problem, and that ( to my shame) is as far as I got. I guess I kind of froze like a rabbit caught in headlights :shock: . But the wood is so dry and worn out that nosings have actually started to split off the front of the treads, and something must be done - and quick!
Anyway, the upshot is it looks like a miracle cure isn't going to come along after all :roll: , and I can't seem to find anyone interested in doing the job for me, well not without winning the lottery or handing over my first born. I've mulled over a couple of schemes to repair it in-situ and nothing really seems likely to satisfy my desire for a permanent and proper solution other than replacing the entire flight (and to be honest, part of me really wants to have a go at making a staircase).
Consequently I've been looking at stair jigs, which frankly seem rather expensive for what they are, and wondering about whether I really need one or whether I can make one to do this one off job. Has any body any experience in this field they would care to share? The 2 jigs in the running are the Axminster one here, or the Trend one, which is about 50% more expensive but has the advantage of using standard 30mm guide bushes rather than the sub-base setup like the Axy. Anyone got either? What are the pros and cons of each one?
Any info or advice gratefully received.
