Mr T
I've spent a while this morning truing up the engineers squares in the tool kits on my student benches. I found that most of them were out of true on the outside edge despite being OK when purchased. This is due to wear from using them with a marking knife. If you've had your square for a while it's worth checking. I fettled mine using a mill file and finishing on a diamond stone to smooth out the file marks. I know this will not give you gnats nagger accuracy but I think it's good enough for general work.
I would be interested to hear from those with mega accurate, and pricey, squares such as Starrett whether they use them for knife marking. Are they harder steel so don't wear, if not how do you restore them to GN accuracy?
Chris
Chris
