Ed H
Hi Guys
As the subject line indicates, I’m new to the world of spraying and am in need of some advice from you all please.
I’ve been using a foam roller to paint my furniture up until now and while the final result is very acceptable it’s clearly not as good as a sprayed on finish. My next few projects are fairly large so now seems a good time to make the jump to spraying.
I’ve read lots of posts here and have a good grasp of the space, ventilation and equipment required (I plan to get an Earlex HV5000) as well and the general process (number of coats, de-nibbing etc).
However, where I still need help is on the type of paint to use. Most of the pro’s on the forum seem to use Morrells AC or Pre-cat but I have little knowledge of these paints and they seem to have a very limited life once opened/mixed. I could be completely wrong, but if not this doesn’t seem like the right paint for me to use.
When using the roller I have used a water based MDF primer and Dulux Diamond Eggshell which both go on easily, dry fairly quickly and seems to be hardwearing. Can these types of paint be used for spraying?
I guess my question in a nut shell would be what type of paint (primer and top coat) would you guys suggest I use as a hobbyist who’s new to spraying ?
Thanks in advance for the help.
Ed
Ed
