This is a new thread I have started following on from my 'Help me spend £20k on a small joinery workshop' post.
Among the machines I have ordered from CMC Italia is a spindle moulder with the following specifications:
‐ Fixed working table dimensions mm 1100 X 640
‐ Sliding table dimensions mm 360 x 1100
‐ Standard spindles ø mm 30 ‐ 35 ‐ 40 ‐ 50 ‐ 1¼
‐ Max. ø table opening mm 350 x 80
‐ Vertical stroke with spindle ø 35/30/1¼ mm 140
‐ Vertical stroke with spindle ø 40/50 mm 180
- 45 degree tilting spindle with electronic readout
‐ Working table height mm 890
‐ Spindle speeds rpm 2500/4200/6000/8000/10000
‐ Motor power HP 7,5
‐ Weight Kg 600
I want to make simple casement and Yorkshire sliding sash windows, doors and tongue and groove flooring.
I have to decide what diameter spindle the machine should be supplied with.
I was rather struck by the Trend Tooling Modular Window and Door systems. They run on a 30mm diameter spindle and, as complete sets, probably comprise of more moulding tools than I really need. They are attractive for their ease of set up but I am concerned a 30mm spindle may not exploit the full potential of my machine.
Given that I still have the choice of spindle diameter, what tooling/tooling system would you recommend I use and on which spindle diameter?
‐ Weight Kg 600
