Which Make Of Spindle Moulder Wood Match This Specification?
pollys13
19 Apr 2009
Swindon
Which makes and models would fit this specification?
Sliding table, 30mm spindle shaft diameter, usable spindle shaft height of 120mm, 7.5HP 3 phase motor, spindle speed 3500 RPM - 9000 RPM, 220mm hole diameter in table, 240mm diameter inside the hood with clear vertical access.
Thanks.
Wood, pun intended :)
Probably any S/M with a motor that size would fit the bill. Felder/ Hammer and such if you have deeper pockets,
otherwise old cast iron machines and a bit of elbow grease...
