SAEngraver
Hello I have a sparse workshop, but will buy such tools as I may need to do the following:-
I need to drop 8mm thick porcelain tiles of 600mm x 400mm into a recess made in 16mm novoboard
This is chipboard with a melamine face on both sides 16mm thick.
The problem is that a router gives me round corners, I need square corners to fit the tiles nice and comfy in the recess.
Have thought of using a drill with square mortising chissel to make corners and than routing the rest - depth of recess 8mm.
Seems a very long process - I
Any suggestions please
Thank you
Thank you
