boardgamer
It's true!!
Items for sale are;
1. Four Handscrews. SOLD
2. Sandvik F clamp - Price reduced to £10
3. Bessey edge clamp - SOLD
4. FrameCo Steel Strap Clamp - Price reduced to £25
5. Bessey S10 table vice - Price reduced to £10
6. Bessey DuoKlamp 300x85 - SOLD
Postage will be at cost, and obviously I will combine packages where possible.
Item 1 Four Handscrews. £25 for all four.
These were originally from Axminster. They were listed as 186x128mm (but I'm not really sure what those dimensions relate to), see the tape measure in the photo to get a better idea of size. They are in pretty much as-new condition - I may have used one a couple of times. The blurb from Axminster said
"A traditional carpenter’s clamp made to a classic design. These clamps are versatile and functional and can be used to clamp ‘out of square’ pieces or small items as well as regular square sided work. The clamps spread an even pressure over a very large area. The hardwood jaws can be adjusted perfectly parallel or by giving the rear screw an extra turn, the clamping pressure can be transferred onto the tips of the jaws. The screws have threads running in opposite directions so it is easy to adjust the jaw width. The jaws and handles are made from hardwood and all metal parts plated against corrosion."
Item 2. Sandvik screw clamp. Was £15, now reduced to £10
Very sturdy screw clamp from Sandvik. Opening about 200mm , throat about 100mm. Very heavy duty! Old, but excellent condition.
Item 3. Bessey Edge Clamp. £5
Fixes onto parallel or F clamps to clamp an edge. Excellent condition.
Item 4. FrameCo Steel Strap Clamp. Was £40, reduced to £25
Designed for clamping picture frames, but also useful for boxes, drawers, etc. Comes complete with 7 flexible corners, so can be used for up to 8-cornered objects. Hardly used, excellent condition.
Item 5. Bessey S10 Mini Vice. Was £20, reduced to £10
Handy little vice that can be clamped to any "table" with the two included clamps. The jaws can be skewed (or not, as desired). Metal is somewhat oxidised, but undamaged.
Item 6. Bessey DuoKlamp 300x85. £15
Bessey 1-handed clamp. Very good condition.
Items for sale are;
